Retrieving Old Share
FWilson
I am new to the forum but been using freenas couple years now but never had ang issue before, reset my network at the CLI and now i am unable to mount my disk are view my share, can some help? I am running freenas11.2.
D
dlavigne
Guest
What type of share? What type of client? What exact error message?
FWilson
Thanks for the reply, I am not getting any error messages, First, because I could not access the share i created a new pool and a new share hoping i could import the old share into the new one. When I try to import the ZFS Volume there is no volume showing up in step two the volume not showing up that box is blank. Second, I try importing the Dick, the dick showed up in the disk area (ad1p2, ad2p2) so I can click the drop down box and select the dick to import, but, the destination box is not showing any destination for me select and i am not sure how to point to a destination. If I put the shared path in I get an error that say "path cannot be found". I did search the forum and found people with similar question and some left on answered and other said they solve it but did not say how. I also try to follow the freenas instruction.
D
dlavigne
Guest
How exactly did you create the new pool? Hopefully you did not overwrite the old one?
FWilson
Following the freenas instruction: Fig. 8.1.1 Creating a ZFS Pool Using Volume Manager
D
dlavigne
Guest
If you selected the disks from the previous pool, you reformatted them and the data is gone. Do you have a backup you can restore?
FWilson
I did it as if I was starting from scratch by creation a user account and create the pool and then the share as I did the first time years ago.
FWilson
I do have a backup but not for about two months data, but after creating the pool that's where i got stuck selecting of mounting the disk, or mount the pool.
FWilson
I think you are right because it did ask me to choose a raid and select the disk so if I did that i delete all my data?
