Resizing /var/tmp/.cache
Duncan
I work in a particularly large AD environment, and the local user/group cache created by FreeNAS fills the full 2GB that is allocated by default for the /var/tmp/.cache memdisk.
[root@freenas-test01 ~]# du -ach /var/tmp/.cache/
512B    /var/tmp/.cache/.snap
154M    /var/tmp/.cache/.samba/gencache.tdb
512B    /var/tmp/.cache/.samba/browse.dat
164k    /var/tmp/.cache/.samba/netsamlogon_cache.tdb
8.0k    /var/tmp/.cache/.query/__db.001
12k    /var/tmp/.cache/.query/__db.002
12k    /var/tmp/.cache/.query/__db.003
12k    /var/tmp/.cache/.query/__db.004
152k    /var/tmp/.cache/.query/.cache.db
196k    /var/tmp/.cache/.query
8.0k    /var/tmp/.cache/.ldap/.activedirectory/.local/.users/UA/__db.001
12k    /var/tmp/.cache/.ldap/.activedirectory/.local/.users/UA/__db.002
12k    /var/tmp/.cache/.ldap/.activedirectory/.local/.users/UA/__db.003
12k    /var/tmp/.cache/.ldap/.activedirectory/.local/.users/UA/__db.004
71M    /var/tmp/.cache/.ldap/.activedirectory/.local/.users/UA/.cache.db
  0B    /var/tmp/.cache/.ldap/.activedirectory/.local/.groups/UA/__db.001
512B    /var/tmp/.cache/.ldap/.activedirectory/.local/.groups/UA
1.0k    /var/tmp/.cache/.ldap/.activedirectory/.local/.groups
8.0k    /var/tmp/.cache/.ldap/.activedirectory/.users/UA/__db.001
12k    /var/tmp/.cache/.ldap/.activedirectory/.users/UA/__db.002
12k    /var/tmp/.cache/.ldap/.activedirectory/.users/UA/__db.003
12k    /var/tmp/.cache/.ldap/.activedirectory/.users/UA/__db.004
1.7G    /var/tmp/.cache/.ldap/.activedirectory/.users/UA/.cache.db
1.9G    /var/tmp/.cache/
1.9G    total
[root@freenas-test01 ~]# df -h
/dev/md3 1.9G 1.9G -153M 109% /var/tmp/.cache
Now, I can stop Directory Services, delete the memdisk using mdconfig, create a larger one, and restart directory servers; similar to what is mentioned in the following ticket: https://bugs.freenas.org/issues/991. However, this is a volatile change, and will be lost on reboot.
My question is, is there a permanent way to resize the memdisk allocated for /var/tmp/.cache, or a safe way to redirect it to a pool, that won't get randomly murdered due to it not being stored in the configuration database?
/var has a file in /conf/base/var/md_size that controls the memdisk size for /var, but I could find no such file for /var/tmp/.cache.
[root@freenas-test01 ~]# find / -name 'md_size'
/etc/md_size
/mnt/md_size
/var/md_size
/conf/base/etc/md_size
/conf/base/mnt/md_size
Holy smokes. I don't have the answer, but I've emailed someone to see if they have the answer.
But you gotta tell me.... how absurdly big is your AD environment? This has to be humongous.
Duncan
Thanks cyberjock. Last I checked, we had about 600,000 AD objects.
