I just wanted to upgrade my pool (2 mirror vdevs, 2x3TB and 2x4TB) by replacing the 3TB disks with 2x12TB HDDs.
So I started resilvering the 3TB HDDs one by one to the 12TB disks. This seemed to work well. However, the available storage didn't increase, so I clicked "Expand" in the storage overview.
This resulted in this error:
I obviously restarted after that, which lead to the pool being degraded, showing a ghost disk, which I replaced with the "unassigned" 12TB again, waiting for the resilvering to complete.
I'm not sure how to move on now. autoexpand is enabled in ZFS, so it should handle the expand itself. I just ran a scrub as the disk I re-assigned showed a checksum error, but I'm a little concerned, as my status shows that one disk with the mount name instead of the device ID:
What's the best way to move on from here?
[EFAULT] Command partprobe /dev/sde failed (code 1): Failed to add inotify watch for /run/udev: Too many open files Error: Partition(s) 1 on /dev/sde have been written, but we have been unable to inform the kernel of the change, probably because it/they are in use. As a result, the old partition(s) will remain in use. You should reboot now before making further changes. Failed to add inotify watch for /run/udev: Too many open files
