resilio; after update to ver. 2.4.4 it does not work anymore
Kirschenhofer
I have FreeNAS-9.10.2-U2 (e1497f2). After I updated my resilio to version 2.4.4 resilio stopped working. I deleted resilio and reinstalled it but without any luck. I can not switch on the resilio plugin from off to on ("some error occured").
Within the jail I have ping connection to the Freenas host.
Any ideas?
Thanks
Joshua Parker Ruehlig
within the jail can you ping another computer on the network?
what does this output in the jail 'service resilio onestart'
Kirschenhofer
yes, I can ping another Computer on my network
´service resilio onestart´ gives me a ´resilio already running? ( pid=...)´
but I can not swich it on
I assume your FreeNAS webui is having connection issues with the plugin's middleware interface. does the resilio icon show on the plugins>installed tab?
can you access resilio? jail_IP:8888
one thing I need to do is disable VIMAGE and assign a network interface to my jails. then restart the jails and their icons show on the plugins>installed tab
I gave you a diagnoses (the middleware issue) and a possible solution (disabling VIMAGE).
lol, welcome. not sure if your issue is solved to your liking
Kirschenhofer
I still have to check. But for now the most important thing is that resilio is running and I have access to it again. Great!
