SOLVED Reporting only shows null for every sensor
ECC
in the past my system was showing every sensor reading correctly. However, this ended somehow and now i only get "null" for every senros reading.
I checked if:
- BIOS date&time matches OS date&time
- Reset Reporting via
midclt call reporting.clear
pgrep -fl collectd
1917 daemon: /usr/local/sbin/collectd[1918]
1918 /usr/local/sbin/collectd -f
pgrep -fl rrdcached
1818 /usr/local/bin/rrdcached -s www -l /var/run/rrdcached.sock -p /var/run/rrdcached.pid -w 3600 -f 7200 -s www -l /var/run/rrdcached.sock -p /var/run/rrdcached.pid
I don't know how to fix this, please help. My Setup is in the signature. Thank you!
