altano
- Jun 6, 2021
I've been trying to get replication of a pool to a remote server working and I keep hitting roadblocks (like this guy). My current issue: the replication stalled. In the Replication Tasks UI it says it is running but it hasn't made progress in over a week. I can see in Task Manager that there's a "replication.run" still running but there are past runs that failed, and I can see the error logs for those.
The replication task config:
The errors:
I believe the last line about the destination not existing is the error that killed the replication. I can confirm with
The errors:
[2021/09/15 15:52:16] INFO [Thread-50] [zettarepl.paramiko.replication_task__task_1] Connected (version 2.0, client OpenSSH_8.4-hpn14v15)
[2021/09/15 15:52:16] INFO [Thread-50] [zettarepl.paramiko.replication_task__task_1] Authentication (publickey) successful!
[2021/09/15 15:52:22] INFO [replication_task__task_1] [zettarepl.replication.run] For replication task 'task_1': doing push from 'tank' to 'backup/holodeck4-tank' of snapshot='auto-2021-09-11_17-00' incremental_base='auto-2021-09-11_16-00' receive_resume_token=None encryption=False
[2021/09/15 19:21:26] ERROR [replication_task__task_1] [zettarepl.replication.run] For task 'task_1' unhandled replication error ExecException(1, "Warning: backup/holodeck4-tank/root/truenas-VMs/pbs: property 'sharenfs' does not apply to datasets of this type\nWarning: backup/holodeck4-tank/root/truenas-VMs/pbs: property 'mountpoint' does not apply to datasets of this type\nWarning: backup/holodeck4-tank/root/truenas-VMs/pbs: property 'sharesmb' does not apply to datasets of this type\ncannot receive incremental stream: destination 'backup/holodeck4-tank/root/videos' does not exist\n")
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 163, in run_replication_tasks
retry_stuck_replication(
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/stuck.py", line 18, in retry_stuck_replication
return func()
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 164, in <lambda>
lambda: run_replication_task_part(replication_task, source_dataset, src_context, dst_context,
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 257, in run_replication_task_part
run_replication_steps(step_templates, observer)
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 586, in run_replication_steps
replicate_snapshots(step_template, incremental_base, snapshots, encryption, observer)
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 637, in replicate_snapshots
run_replication_step(step, observer)
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/run.py", line 714, in run_replication_step
ReplicationProcessRunner(process, monitor).run()
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/process_runner.py", line 33, in run
raise self.process_exception
File "/usr/local/lib/python3.9/site-packages/zettarepl/replication/process_runner.py", line 37, in _wait_process
self.replication_process.wait()
File "/usr/local/lib/python3.9/site-packages/zettarepl/transport/ssh.py", line 151, in wait
stdout = self.async_exec.wait()
File "/usr/local/lib/python3.9/site-packages/zettarepl/transport/async_exec_tee.py", line 103, in wait
raise ExecException(exit_event.returncode, self.output)
zettarepl.transport.interface.ExecException: Warning: backup/holodeck4-tank/root/truenas-VMs/pbs: property 'sharenfs' does not apply to datasets of this type
zfs list that the dataset mentioned does not exist on the destination. Why is this one dataset not being automatically created? I didn't create any of the others manually and the backup should obviously handle that.
