Replication stops during scrubs on PULL
Matt Stofko
I'm having an issue where replication stops during scrubs. I have a snapshot task set to run every 5 minutes, which is working perfectly. However, the snapshots stop replicating to my remote machine while a scrub is running on that remote machine. A scrub can be running on PUSH with no problem, it's when PULL is running a scrub that it stops. Is this a configuration error with my setup? Has anyone else seen this? I don't see it as documented behavior. As soon as the scrub finishes, replication starts up again almost immediately.
Thanks,
Matt
