Replication problem FN 11 Release->FN 9.2.1.9
enemy85
Hi all,
recently i set up a second FN box as backup for the main one:
main FN box (let's call it "A") runs with FreeNAS-9.2.1.9-RELEASE-x64 (2bbba09)
backup FN box (called "B") runs with FreeNAS-11.0-RELEASE (a2dc21583)
Replication from A to B has been working for a long time, and even after moving the 2 boxes away from each other, keeps working.
I tried to set a replication task from B to A (of a small, brand new "test" folder), and i did exactly all the steps i was supposed to do to make it work:
1) set up periodic snapshot of "test" folder on box B
2) set up replication task on box B (with ssh key scan working and finding the key)
3) copy and paste SSH public key of box B in root user of box A
The replication starts and run for all the time it needs (i can see the increasing % in the replication task tab on box B and i can se the stream on the network report graph), the problem is that at the end of the stream, in box A i can see the dataset created, but it looks empty, and i keep having in the running processis "zfs" at 100% for ever, while in the replication task tab of box B the status remain "sending" forever.
I tried to re-do it from scratch many times, even changing user, but can't solve the problem...
Any clues???
TIA
D
dlavigne
Guest
Might be a bug. Please create a bug report at bugs.freenas.org and post the issue number here.
enemy85
a Bug? Is it possible that nobody tried replication or do you think might be a bug just with a 9.2.1.9 target system?
I'm just worried it could be a stupid thing I am not considering...don't want to open a bug report if i'm not sure all i did was exact...
can't someone try to replicate it?
enemy85
Bug #24762
D
dlavigne
Guest
Replication changed significantly between those 2 versions so there might be something that needs to be migrated (in the backend db) for this to work. The dev will be able to offer some more insight.
