Replication issues . Temp Auth Token
kjemison
I have a Primary server running FN 11.2 and trying to "Push" replication to FN 11.3
The Primary system under Semi Automatice Setup is asking for a Temporary Auth Token from the 11.3 system.
I have looked and looked for that and cannot locate it. Searched the documentation and it makes no mention of it.
Any help would be appreciated .
Thank you
Kell
kjemison
Ended up just loading FN 11.2 which actually has the "Button" on the Replication page to Create a "Replication Token"
Still would like to know where the "Replication Token" Button is located on the latest version of FN....
Under System | SSH Keypairs ?
I see an item there called "Legacy Replication SSH Key Pair", which has buttons on it (when edited) that look like what you're asking for.
