Replication Failed
NasKar
I started to backup my server to my backup server by creating a Periodic Snapshot Task of the pool v1. The replication task was semi automatic to the backup server at tank/Supermicro. It was working fine for 3 days and now I got an email "Replication v1 -> 192.168.5.50:tank/Supermicro failed: Failed: v1 (auto-20190115.1746-1d) "
Any ideas on how to figure what went wrong. Thanks.
NasKar
The replication process just restarted on its own. Since then I believe after a power failure (both servers are on the same UPS I started getting :
Replication v1 -> 192.168.5.50:tank/Supermicro failed: Failed: v1/iocage/releases/11.2-RELEASE/root (lazylib2->plexpass)
Will have to do some testing on the UPS system.
Is there a way to fix the error or should I delete the snapshots on both systems and restart the process?
D
dlavigne
Guest
Checking the box to Delete Stale Snapshots on Remote System should resolve the error.
