Tha_Reaper
- Dec 2, 2023
I run a daily replication task of my apps pool to my storage pool. Everything went great for a couple of weeks, but now i get a couple of errors without changing any settings:
I tried creating a new dataset to send the replication to, but it immediately gives the same errors. I also tried stopping all the apps and then replicating, but that also doesnt work.
Im a bit worried that my replication is incomplete, so that if my apps SSD decides to crash, that i may lose everything.
i run TrueNAS-SCALE-23.10.2
cannot mount '/mnt/Klemmers/appbackup2/releases/homarr/volumes/pvc-447bab69-9a9a-40a9-9291-5b65200c9cf3': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/homarr/volumes/pvc-4b9908af-153a-4edc-8d07-ac5d73c09035': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/homarr/volumes/pvc-e1cef352-bbaa-4547-b312-ffe5f928f1bf': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/radarr/volumes/pvc-bfe773f1-bc89-49b6-afa4-c1b28fefe22f': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/sonarr/volumes/pvc-3c7f4e01-d9d9-43f1-b999-737f6dac908f': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/jellyfin/volumes/pvc-7c190c8f-d3cf-401f-828f-12b3f8ccc1ab': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/jellyfin/volumes/pvc-90808052-f7c0-4e22-b42a-8553a8514691': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/prowlarr/volumes/pvc-2311f692-6783-46ba-b8a1-6e8a9f89faeb': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/jellyseerr/volumes/pvc-695216d9-9079-4ec0-8804-9702e8b64043': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/qbittorrent/volumes/pvc-182bb1b5-8b91-49e3-9a51-190abd067b33': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/flaresolverr/volumes/pvc-98f1fffa-4ab4-42a7-8722-54b443a1573b': failed to create mountpoint: Read-only file system cannot mount '/mnt/Klemmers/appbackup2/releases/audiobookshelf/volumes/pvc-f0f24c6a-745d-4cf5-86d0-8fc1d529a2a6': failed to create mountpoint: Read-only file system
