Replication between FreeNAS & TrueNAS machines (bare metal)
Bikerchris
Hello all,
Before I install TrueNAS on a separate machine and try replication from a FreeNAS machine to it, could anyone confirm if Replication works OK between the old and new?
Many thanks,
Chris
Redcoat
Well, an 11.3-U5 replication task failed when I put TrueNAS on my backup target box as a test. Not wanting to lose my daily backup I reverted the backup box back to 11.3 to wait for TrueNAS's first update.
During that time the TrueNAS docs had an addition on the topic of legacy replication - see https://www.truenas.com/docs/hub/tasks/scheduled/replication/legacy/
Bikerchris
Thank you for that, really kind. I'll install FreeNAS as a precaution, very much appreciated.
trentk10
I successfully do replication from my truenas machine to another computer in the house running freeBSD 12.2.
Bikerchris
Thanks for that, very useful to know.
Juan Manuel Palacios
If I may ask, how did you accomplish that? I recently upgraded to TrueNAS 12.0-U2.1 and started seeing failures for all my replication tasks that go out to a vanilla FreeBSD 12.2 box, and that setup had been working for a long time while I was running FreeNAS 11.x on the local side.
I believe the culprit is TrueNAS 12's use of OpenZFS 2.0, and particularly its attempt to use 'zfs receive -x' on the receiving side, as FreeBSD 12's ZFS stack is pre OpenZFS 2.0, and doesn't have 'receive -x'. The error I'm getting all over the place is, precisely:
failed: invalid option 'x' usage: receive|recv [-vnsFu] receive|recv [-vnsFu] [-o origin=] [-d | -e] (…)
Most probably I can very easily get around that by running zfs send --options | ssh host 'zfs receive --options' manually on the command line, but I'm curious if there's something I can do in the TrueNAS GUI to keep my replication tasks working while I wait for FreeBSD 13 to be released.
Thanks,
I just got my TrueNAS 12 --> FreeBSD 12.2 ZFS push replication setup working by using the SSH+NETCAT transport (which required figuring out the active & passive roles and opening up firewall ports accordingly), as opposed to plain SSH, which is what I'd been using so far.
So I guess I'll stick with that until either FreeBSD 13 comes along (which, if I'm not mistaken, will bring OpenZFS 2.0), or until I receive advice on how to get the setup working again with the plain SSH transport prior to upgrading to FreeBSD 13, which is what I'd prefer.
Thanks,
And as stated here:
My FreeBSD 12.2 box of course needed to have a slew of packages installed to make the SSH+NETCAT transport work, particularly python3, python37, and py37-libzfs.
HTH!
