Replicated datasets does not show in dir listing
eccevery
Since migrating from FreeNAS to TrueNAS I've been having some issues with replication. I started another thread on the replication issues itself, but at this point I have managed to get around it and now replication is running but I cant see any files on the target server.
Quick background: After upgrading to TrueNAS 12 replications stopped working. I tried to start replication over (deleting snapshots, replication tasks etc) but no matter what I did the replication either failed or replicated a few kilobytes. I finally worked around the problem by manually copying files to a new harddrive I installed temporarily in the main storage server and then replicated THOSE datastores.
The problem is that I cannot see the files on the target device:
However, the datasets show up in the GUI under storage and in zfs list:
I suspect this may have to do with nested datasets that I have created on the temporary disk that I used to created replications from. I created a dataset on the temprary drive called "backup_pool" and on that drive several child datasets. Three of those you see in the screenshot above (replicated to the backup server). I have not replicated the "backup_pool" dataset, maybe that somehow messes things up? This is the replication settings for the music dataset:
I'm a bit confused and don't really know what I'm doing at this point. Have I set up the replication wrong somehow? Wy does not anything show up in the backup server on tank2?
eccevery
Solved it! Dataset on target server was read-only, causing filesystem to not mount:
root@pluto:/mnt/tank2 # zfs get all tank2/music_backup
NAME                PROPERTY               VALUE                    SOURCE
tank2/music_backup  type                   filesystem               -
tank2/music_backup  creation               Sat Nov 21 20:32 2020    -
tank2/music_backup  used                   23.8G                    -
tank2/music_backup  available              6.84T                    -
tank2/music_backup  referenced             23.8G                    -
tank2/music_backup  compressratio          1.00x                    -
tank2/music_backup  mounted                no                       -   <---------
tank2/music_backup  quota                  none                     received
tank2/music_backup  reservation            none                     received
tank2/music_backup  recordsize             128K                     default
tank2/music_backup  mountpoint             /mnt/tank2/music_backup  default
tank2/music_backup  sharenfs               off                      default
tank2/music_backup  checksum               on                       default
tank2/music_backup  compression            off                      default
tank2/music_backup  atime                  on                       default
tank2/music_backup  devices                on                       default
tank2/music_backup  exec                   on                       default
Tried to mount it:
root@pluto:/mnt/tank2 # zfs mount tank2/music_backup
cannot mount '/mnt/tank2/music_backup': failed to create mountpoint: Read-only file system
Checked the settings on target server pool:
Changed read-only setting to false, mounted filesystem and all looks good!
