- Jul 3, 2015
I might be a little late to the party but I've had a search around the forums and although I've found one or two posts suggesting that replicated datasets should be set to readonly I didn't actually realise that this had been implemented. Last time I checked which was a little while ago this was not the case.
Therefore I just wanted to check that if you should ever want your replicated datasets to not be readonly I assume the only/best way to do this would be from the command line using:
zfs set readonly=off tank/dataset
Appreciate any thoughts.
