gzartman
- Nov 1, 2013
I'm trying to use the replication function in FreeNAS to replicate 2 zvols to a second freenas box.
I have the snapshoting and SSH working properly, but the replication says it can't open the "dataset" I'm trying to replicate. Do I need to create the exact zvol on the PULL side for this to work?
I see the following error message one the PUSH box: CRITICAL: Oct. 15, 2016, 7:46 p.m. - Replication Main/Backups/VMs -> 172.23.0.3:Main failed: Failed: cannot open 'Main/Backups/VMs/Backups/VMs': dataset does not exist.
172.23.0.3 is my PULL box.
The ZVOL I'm trying to replicate is "Main/Backups/VMs"
In the replication task, for Remote ZFS Volume/Dataset, I put: Main/Backups/VMs
Thanks
Thanks
