I currently run a 2TB single disk pool and want to replace it with a two 8TB mirror.
I want to replace the 2TB single hdd pool 'pool1' by attaching a 8TB drive, to create a mirror 'pool1', and then replacing the small 2TB with a 2nd 8TB drive, and resilvering.
Would this scenario work?
Unfortunately I couldn't find a way to do it in the webgui. I even cannot create a single disk pool from the recognized 8TB WD EDAZ hdd. Is that as expected?
I found this thread similar https://www.truenas.com/community/t...-larger-disks-mirrored-how.82328/#post-569827
Maybe the single disk pool 'pool1' is a stripe pool, and therefor I'm no able to add a mirror disk to expand it into a mirror?
But why I'm not able to create an 8TB single drive pool at all in the webgui?
I'm using FreeNAS 11.3-U5 on a HP microserver N40L. I attached 5 Disks (one on the ATAPI/SATA connector for an optical drive or tape drive) and got a mirrored UltraFit pendrive rpool.
Would upgrading to TrueNAS 12 help with the pool management in the webgui? I read a lot of hassle regarding upgrading the FreeNAS to TrueNAS e.g. with smb and root access etc.
NAME STATE READ WRITE CKSUM
pool1 ONLINE 0 0 0
gptid/b7b60347-2077-11e2-942a-009c02975d54 ONLINE 0 0 0I want to replace the 2TB single hdd pool 'pool1' by attaching a 8TB drive, to create a mirror 'pool1', and then replacing the small 2TB with a 2nd 8TB drive, and resilvering.
https://www.ixsystems.com/documentation/freenas/11.3-U5/storage.html#extending-a-poolto extend a ZFS mirror, add the same number of drives. The result is a striped mirror. For example, if ten new drives are available, a mirror of two drives could be created initially, then extended by adding another mirror of two drives, and repeating three more times until all ten drives have been added.
