Robert ikin
 - May 1, 2015
I've been using Freenas on an old Dell machine (Optiplex 780) for about a year, I'm really happy my present Freenas configuration and it's performance. However the motherboard has only two internal SATA ports one of which I recently discovered is broken, I want to install a second HD with the possibility of further storage expansion (not happy using SATA expansion card). I have a Gigabyte GA-G41MT-S2P (4 SATA ports) kicking about that I would like to put in the Dell box using the existing memory, cpu and HD. Can I do the swap without losing the data on the HD and keep the current install config on the USB stick or is it an upgrade from the current version CD or a complete reinstall job of the Freenas OS and plugins
