Hi everyone!
im runing Truenas Scale 22.12.3.3
CPU: CPU E5-2680 v3
RAM: 256GB ECC samsung ram
Storage: 10 Toshiba MG04SCA60EA 6TB sas drives (12G)
Network: 10Gig
I have 1 pool with 2 raid z1
The pool status is OK! just finished a scrub yesterday - no errors on any disk.
I bought new drives - 17 of the Segate Exos X16 10TB (all new)
I want to change the entire setup - i even bought a new motherboard (supermicro x10dri - using 2 of the 2680 v3)
The question is - what should i do about replacing the drives?
Should i build the new server containing 3 raid z1 (5 drives each) and move the data?
Or should i replace the current disks and expand the pool and then replace the hardware?
If its important in any way - i used to change the current disks (i had 5 of the 4tb WD red plus drives, and i changed them the toshiba drives and added 5 more to have the current setup)
CPU: CPU E5-2680 v3
Network: 10Gig
