Hi there,
1st post, already searched without an exact match.
System: FreeNAS-9.2.0-RELEASE-x64/
Situation. a 3 disks zpool with a problem in a single disk
I did "zfs set readonly=on Local1" and I think, stabilized the problem
I managed to copy most of the files to an external disk, now I want to remove the defected disk
Now the poll is about 25% used (enough to fit the remaining data in 2 disks).
Any way to put all the data (readable data) in the disks working ok? And remove the defected one?
Without having Perl support in free nas(I do perl a lot). I manage to copy most of my files with a Python script ( I've never had programmed in python before), but could help someone in the same situation(suggestions?).
best regards,
[root@freenas] /mnt/Local1# zpool status -v Local1
pool: Local1
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 11h56m with 1 errors on Sun Sep 28 11:56:03 2014
NAME STATE READ WRITE CKSUM
Local1 ONLINE 2 0 0
ada1p2 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
ada3p2 ONLINE 2 0 0
/mnt/Local1/movies/XXX.Bluray.x264.CBGB.mkv
[root@freenas]
pool: Local1
state: ONLINE
Local1 ONLINE 2 0 0
ada1p2 ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
ada3p2 ONLINE 2 0 0
[root@freenas]
#!/usr/local/bin/python import os, re import datetime import shutil #src_dir = "/mnt/Local0/_pictures/" src_dir = "/mnt/Local0/pict_repetidas/" dst_dir = "/mnt/DSK/pictures_2014-09/" logArr = [] errArr = [] def modification_date(filename,count): basename = os.path.basename(filename) head, tail = os.path.splitext(basename) t = os.path.getmtime(filename) out = datetime.datetime.fromtimestamp(t) #out =head+'{:_%Y%m%d_%H%M%S.%f}'.format(out)+tail if(count > 0): out =head+'{:_%Y%m%d_%H%M%S}'.format(out)+"-"+str(count)+tail else: out =head+'{:_%Y%m%d_%H%M%S}'.format(out)+tail return out.upper().replace(" ", "_") def copy_files(src,dst): try: fileNum = 0 for root, dirs, files in os.walk(src_dir): cnt = 0 for file_ in files: src_ = os.path.join(root, file_) fname_ = modification_date(src_, cnt) dst_ = dst+fname_ while(os.path.exists(dst_)): #rename if already there cnt += 1 fname_ = modification_date(src_, cnt) dst_ = dst+fname_ errArr.append(src_+ " >>> " + dst_) cnt = 0 shutil.copy(src_, dst_) logArr.append(src_ +" >> "+ dst_) fileNum += 1 print "ficheiros processados: "+str(fileNum) except (IOError, os.error) as why: errArr.append((src_, str(why))) copy_files(src_dir, dst_dir) errFile = open("errlog.txt", "w") for item in errArr: errFile.write("%s\n" % item) errFile.close() logFile = open("pictlog.txt", "w") for item in logArr: logFile.write("%s\n" % item) logFile.close() # vim: ai ts=4 sts=4 et sw=4 ft=python
best regards,
