Hi Guys,
I did a fresh install of FN 11.2 BETA3 and imported my pool (without the configuration), i would like to do a cleanup in the pool to neath things up and make some space. listing the pool i can see 13GB of warden template plugin jails, are these an old jails i created perviously? can i remove them? if so what is the proper command\way to delete this files completely? i don't have/need any plugin anymore and i will use iocage for new jail only.
Regarding iocage, after the fresh install when creating new jail, the jail number come up as #30. i assume it continue from the last one i created inn older FN versions. can i reset to start from 1? sorry tidy freak
Thank you in advance
[root@freenas ~]# zfs list NAME USED AVAIL REFER MOUNTPOINT Tank 3.41T 16.6T 256K /mnt/Tank Tank/.bhyve_containers 115M 16.6T 115M /mnt/Tank/.bhyve_containers Tank/.system 226M 16.6T 299K legacy Tank/.system/configs-85575f3640124e06b9ead9eeda4080b1 188K 16.6T 188K legacy Tank/.system/configs-9adeaf1b34484300be9487bd23ab62d6 66.7M 16.6T 66.7M legacy Tank/.system/configs-a7c4a4a3d45a4720a1e6b8ad799731fd 188K 16.6T 188K legacy Tank/.system/configs-c6df7f068c2c4171917a68f70a853917 341K 16.6T 341K legacy Tank/.system/cores 5.47M 16.6T 5.47M legacy Tank/.system/rrd-85575f3640124e06b9ead9eeda4080b1 21.9M 16.6T 21.9M legacy Tank/.system/rrd-9adeaf1b34484300be9487bd23ab62d6 30.8M 16.6T 30.8M legacy Tank/.system/rrd-a7c4a4a3d45a4720a1e6b8ad799731fd 21.7M 16.6T 21.7M legacy Tank/.system/rrd-c6df7f068c2c4171917a68f70a853917 16.4M 16.6T 16.4M legacy Tank/.system/samba4 1.03M 16.6T 1.03M legacy Tank/.system/syslog-85575f3640124e06b9ead9eeda4080b1 452K 16.6T 452K legacy Tank/.system/syslog-9adeaf1b34484300be9487bd23ab62d6 59.9M 16.6T 59.9M legacy Tank/.system/syslog-a7c4a4a3d45a4720a1e6b8ad799731fd 384K 16.6T 384K legacy Tank/.system/syslog-c6df7f068c2c4171917a68f70a853917 341K 16.6T 341K legacy Tank/.system/webui 188K 16.6T 188K legacy Tank/.warden-template-pluginjail 684M 16.6T 684M /mnt/Tank/.warden-template-pluginjail Tank/.warden-template-pluginjail-11.0-x64 684M 16.6T 684M /mnt/Tank/.warden-template-pluginjail-11.0-x64 Tank/.warden-template-pluginjail-11.0-x64-20180612024824 684M 16.6T 684M /mnt/Tank/.warden-template-pluginjail-11.0-x64-20180612024824 Tank/.warden-template-pluginjail-11.0-x64-20180612030118 684M 16.6T 684M /mnt/Tank/.warden-template-pluginjail-11.0-x64-20180612030118 Tank/.warden-template-pluginjail-11.0-x64-20180612043450 683M 16.6T 683M /mnt/Tank/.warden-template-pluginjail-11.0-x64-20180612043450 Tank/.warden-template-pluginjail-11.0-x64-20180612103032 684M 16.6T 684M /mnt/Tank/.warden-template-pluginjail-11.0-x64-20180612103032 Tank/.warden-template-standard-11.0-x64 3.04G 16.6T 3.04G /mnt/Tank/.warden-template-standard-11.0-x64 Tank/.warden-template-standard-11.0-x64-20180313141143 3.05G 16.6T 3.05G /mnt/Tank/.warden-template-standard-11.0-x64-20180313141143 Tank/.warden-template-standard-11.0-x64-20180612231357 3.06G 16.6T 3.06G /mnt/Tank/.warden-template-standard-11.0-x64-20180612231357 Tank/SMB 2.46T 16.6T 2.46T /mnt/Tank/SMB Tank/TimeMachine 933G 66.8G 933G /mnt/Tank/TimeMachine Tank/Windows Backup 22.7G 177G 22.7G /mnt/Tank/Windows Backup Tank/iocage 526M 16.6T 3.62M /mnt/iocage Tank/iocage/download 126M 16.6T 188K /mnt/iocage/download Tank/iocage/download/11.2-RELEASE 126M 16.6T 126M /mnt/iocage/download/11.2-RELEASE Tank/iocage/images 188K 16.6T 188K /mnt/iocage/images Tank/iocage/jails 188K 16.6T 188K /mnt/iocage/jails Tank/iocage/log 188K 16.6T 188K /mnt/iocage/log Tank/iocage/releases 396M 16.6T 188K /mnt/iocage/releases Tank/iocage/releases/11.2-RELEASE 396M 16.6T 188K /mnt/iocage/releases/11.2-RELEASE Tank/iocage/releases/11.2-RELEASE/root 396M 16.6T 396M /mnt/iocage/releases/11.2-RELEASE/root Tank/iocage/templates 188K 16.6T 188K /mnt/iocage/templates Tank/isos 188K 16.6T 188K /mnt/Tank/isos Tank/vm_block 4.34G 16.6T 4.34G - Tank/vm_nfs 1.81G 16.6T 1.81G /mnt/Tank/vm_nfs freenas-boot 886M 12.2G 64K none freenas-boot/ROOT 884M 12.2G 29K none freenas-boot/ROOT/Initial-Install 1K 12.2G 882M legacy freenas-boot/ROOT/default 884M 12.2G 882M legacy
