Remove stripe in a mirror volume
sbeaulieu
wanted to replace a disk in my mirror volume in ZFS, using FreeNas 8.3.0 release. but it was not working. I was thinking I need to add it first using Volume manage to extent my mirror volume. but it add my a stripe.
Is it a posible to remove it ?
SB
Nope. Once it's added the only way to remove it is to destroy the zpool.
Come to think of it that really sucks for you. :((
I'm betting you had a mirror, one of the disks failed so you tried to replace it. Bought a new disk and put it in. But now you have no spare disk to rebuild the zpool and no redundancy either.
sbeaulieu
What will be the best step to resolve my probleme. I have a third disk that I can use.
Copy your data to the third disk, destroy your zpool and recreate it with the 2 good disks. Then copy the data back to the zpool.
sbeaulieu
How should I copy my data... using Freenas or from outside of my FreeNas server.
Can I Create a new volume and copy to this other volume
I'd copy it whichever way you feel most comfortable with.
You could create a new volume and copy to that volume.
sbeaulieu
My volume is looking like that
I need to copy only those two files VMWARE_DS2 and VMWARE_DS a other Volume temporary
Delete Volume MAIN
Recreate it.
Recreate child volume
And after replace the newly recreated in /dev/zvol/MAIN/ by the one in the temporary volume
