SOLVED Remove files - "Operation not permitted"
ObiTobi
by my own mistake I copied some things wrong. Now I can't delete them anymore although I'm doing it as root. How do I get it deleted after all?
find test
test
test/bin
test/bin/rcp
test/sbin
test/sbin/init
test/lib
test/lib/libcrypt.so.5
test/lib/libthr.so.3
test/lib/libc.so.7
rm -rf test/
rm: test/bin/rcp: Operation not permitted
rm: test/bin: Directory not empty
rm: test/sbin/init: Operation not permitted
rm: test/sbin: Directory not empty
rm: test/lib/libcrypt.so.5: Operation not permitted
rm: test/lib/libthr.so.3: Operation not permitted
rm: test/lib/libc.so.7: Operation not permitted
rm: test/lib: Directory not empty
rm: test/: Directory not empty
-r-xr-xr-x 1 root wheel 1006464 Mar 25 2016 test/sbin/init
chmod 777 test/sbin/init
chmod: test/sbin/init: Operation not permitted
Samuel Tai
Urk... It looks like you moved these libraries from /lib, and it's not possible to delete them while the system is running.
Please check if /lib/libcrypto.so.5, /lib/libthr.so.3, and /lib/libc.so.7 exist.
ObiTobi
Nope, I moved/ copied files from old "jails" directory
And yes, all libs you have listed are here.
Samuel Tai
Is test a ZFS dataset? If so, then you could just nuke it with zfs destroy <dataset>.
ObiTobi
No, I have copied the files to /tmp directory.
I can understand that open files can not be deleted. But they are not in used, why I can't delete them or change their attributes I absolutely don't understand
Problem solved - "chflags noschg fileName" was the solution
