Remember window and column settings
Glorious1
A minor annoyance is that column adjustments in windows with lists of items are sometimes remembered for a while, but usually not. It would be nice not to have to adjust it every time I look at a window to make it more readable.
BUT - the one place where it is more than a minor annoyance is in Storage > Snapshots. This window requires a lot of setup, choosing a sort order, number to view per window, column widths, and maybe a filter. And this resets to default every time you do something like delete a snapshot. It is super tedious if you're doing a lot of work in there to reset it a dozen times in one session.
D
dlavigne
Guest
This feature is coming in 10 as it will be possible with the new GUI design.
Glorious1
Awesome! Thank you.
