.Recycle permisions
panosvo
I ahve a freenas setup with .recycle enabled. Every user can only see his .recycle, is it possible for a user to have admini permissions so it can see and delete other users recycle folder?
Also how can i empty .recycle automaticaly for files older than 1 month?
I use freenas 8.04
AFAIK there is no way to look at someone else's recycle bin. That's a major security risk between users because each user could view the others files. Not to mention that user A might not want user B to delete their files for them.
I created a cronjob that deletes all files older than 1 month that are in the recycle bin. I figure 30 days is plenty of time to realize you deleted something you need. I believe I posted it on the forum somewhere.
panosvo
Thanks for your answer. I searched in the forum and did not find your post, if you find it i would appreciate it.
