SOLVED Recursive Process
Jacopx
Jacopx
Which process is the repetitive one?
Sorry it was a wrong photos!
Is the first one:
PID: 67937
User: root
Command: Python2.7
With this process my drive never goes on standby! :(
You shouldn't expect it to. Your system will be constantly writing logs, doing maintenance tasks, and other things that will access the pool.
D
dlavigne
Guest
That process is for the FreeNAS GUI so it's needed... It' s more likely that the system isn't going into standby due to writes to the system log and reporting database.
Jacopx
Ohhhhh, sorry, thank you!!! ;)
