This is the second time I've struggled with this issue. My Boot USB died (I'm switching to a boot SATA) and I'm left recovering my config and encryption key for my NAS drives. I have recent backups of both.
The problem is that upon importing the configuration, my encrypted volume exists but will not decrypt. I do not have the recovery key, I have the main key (geli.key). From what I've read, I can detach and re-import the volume with my main key? But that means I have to detach the volume. Is there a way to use the main key + passphrase on a volume without detaching it then importing?
http://doc.freenas.org/11/storage.html?highlight=encrypt#importing-an-encrypted-pool
I think it would be good to have a way to supply the main key + passphrase to decrypt an existing volume. Am I correct in thinking right now, the main method for this is to use the recovery key only (no passphrase)?
