Recovering from various failure scenarios
Rusky
Please point me to articles if they exist but I wanted to know how to recovery from various failure scenarios
1. The OS boots from a USB, what happens if the USB fails?
2. My jail is on a separate SSD drive, what happens if the SSD fails?
3. What happens if the motherboard fails?
4. <insert any other failure scenario>
m0nkey_
You can either backup your config or mirror your boot device.
Without backups, you lose your data. You can store snapshots of your jails on your main pool.
Just move all drives, inc. boot. When you boot up, you will need to reconfigure the NIC.
Rusky
I setup periodic snapshot tasks for the primary storage and the jail but I don't see where the snapshots are being stored. How would I point them to the mail pool?
m0nkey_
You would need to write yourself a script to do this, since it's not an automated task.
Rusky
I have the extra SSDs so it sounds like it'll be best to mirror my jail.
Thanks for your expert simian knowledge :)
Snapshots are always stored on the pool on which they're taken; that's just the way ZFS snapshots work. But you can replicate them to another pool. FreeNAS has built-in replication capabilities, though they are a little cumbersome when replicating to another pool on the same machine.
