Usually I can spend a while to figure these things out through Internet searches but I cannot find anything on this, maybe I am searching using the wrong terms. Anyway...
I had to re-install FreeNas from scratch on my server. I managed to re-connect the volumes OK but I am having problems connecting to the existing Jail that I had Plex installed on. I believe once I FreeNas is connected to the Plex Jail then I could re-install Plex to it? Could someone point me in the right direction?
Thank You
Thank You
