deltabetacooper
- Aug 4, 2021
Currently I have a RAIDZ1 pool that consists of 4 3TB disks. I'm hoping to replace these four disks with three 8TB disks.
Before I do so, is it possible and what is the procedure?
Do I replace the disks one-by-one, resilvering all the way, until I've got all three 8TB disks in there, and then simply remove the remaining fourth 3TB disk from the array? My understanding is that the pool will be built with the remaining 3TB drive being the limiting one and my pool's storage won't have grown. If I remove that 3TB disk from the array, will the pool then grow to use the three bigger disks?
Thank you very much!
