With ZSTD now in 12-Beta2.1, and being a compression system with a lot more flexibility than lz4 and previous, what is a good resource or ixSystems recommendations, for ZSTD adoption over LZ4, and the ZSTD schema(s) recommended and how/when to use each? or is it all "try them all and see!"?
Also for deduped pools does ZSTD tend to result in as many dedupable blocks as LZ4 because for pools that do legitimately runb dedup and get many multiples of deduplication, the gain of 20% compression is trivial if it loses 0.5x in dedup as a result.
I could replicate my 40TB pool half a dozen times, see what the outcome is (for my pool at least), but maybe someone already has preliminary ideas what is typical?
Any insight and guidance valued.
