- Nov 25, 2013
Hi, guys,
bad luck today - my two mirrored system drives failed on the same day leaving the system completely broken. All data on the storage pool is of course intact.
I had used these drives:
https://www.amazon.de/gp/product/B00LFVISSY/
Investigating I found that they were awfully hot. I removed them and plugged them in a stock FreeBSD system to check - nothing but CAM timeouts.
Apart from "don't" ... any advice? I reinstalled on my internal SSD but that's a 240 GB PCIe card. Quite a waste just for the boot pool. Why does FreeNAS use the entire drive and not just, say, 16 GB of it leaving the rest usable for other purposes?
I used to buy "industrial grade" compact flash for my Soekris devices, never had one fail. Are there similar USB flash drives around?
Thanks,
Patrick
Thanks,
Patrick
