EvanVanVan
- Feb 1, 2014
Last month I received emails stating an unretryable error 22 had occurred on da4. With some helpful (https://forums.freenas.org/index.php?threads/error-22-failing-drive.42292/) advice I made sure everything was OK with the drive and even removed encryption from my pool.
A couple of days ago I received a similar error again (attached at the bottom). It was suggested last time that Error 22 may have to do with my LSI card. I'm wondering if my first step should be swapping out my SAS-Sata breakout cables.
But before I do anything I like to check here and ask several rapid fire questions.
1. Is it relatively safe to change cables?
2. I'm assuming I'll need to verify that the breakout cables are plugged into the drives in the same order. Hopefully they they are labeled from the manufacturer 1 through 4?
3. I currently have 2 breakout cables to handle my either drives, both are from monoprice. Should I replace both of them and/or does it matter if I go with a different brand and just replace 1 of them?
freenas.local kernel log messages: > (da4:mps0:0:4:0): WRITE(10). CDB: 2a 00 3f 7b fe 10 00 00 08 00 > (da4:mps0:0:4:0): CAM status: SCSI Status Error > (da4:mps0:0:4:0): SCSI status: Check Condition > (da4:mps0:0:4:0): SCSI sense: ILLEGAL REQUEST asc:21,0 (Logical block address out of range) > (da4:mps0:0:4:0): Info: 0x3f7bfe10 > (da4:mps0:0:4:0): Error 22, Unretryable error -- End of security output --
Checking status of zfs pools: NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT freenas-boot 7.19G 5.62G 1.57G - - 78% 1.00x ONLINE - volume1 21.8T 11.0T 10.7T - 7% 50% 1.00x ONLINE /mnt pool: volume1 state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://illumos.org/msg/ZFS-8000-9P scan: resilvered 8K in 0h0m with 0 errors on Wed Apr 27 02:43:55 2016 config: NAME STATE READ WRITE CKSUM volume1 ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/2a0e67aa-b790-11e3-b9da-002590d65107 ONLINE 0 0 0 gptid/2a82eeea-b790-11e3-b9da-002590d65107 ONLINE 0 0 0 gptid/2afb7434-b790-11e3-b9da-002590d65107 ONLINE 0 0 0 gptid/2b79a9e5-b790-11e3-b9da-002590d65107 ONLINE 0 0 0 gptid/2bf1472f-b790-11e3-b9da-002590d65107 ONLINE 0 0 0 gptid/2c67faef-b790-11e3-b9da-002590d65107 ONLINE 0 1 0 gptid/2cedc0a0-b790-11e3-b9da-002590d65107 ONLINE 0 0 0 gptid/2d7a9191-b790-11e3-b9da-002590d65107 ONLINE 0 0 0 errors: No known data errors -- End of daily output --
