Just want to make sure I have things right in my head before going ahead.
I currently have a single vdev with 6x 2TB and 2x 4TB configured as z2 (The 4TB's have replaced some failed 2TB's)
I have also just ordered 3x 8TB WD Red's and want to migrate my data off of the existing devices to the new.
From my understanding I should be able to set a new vdev with the new drives in z1 and then assign them to a new pool. From there i can copy the data from tank_old to tank_new. Is there any preferred process for this?
Secondly, I have my jails setup on tank_old, but from what I've been reading, moving them to a separate ssd shouldn't be an issue if I follow https://forums.freenas.org/index.ph...ls-to-ssd-helping-hdd-sleep.16955/#post-89106.
Once the data has been moved to tank_new I should be able to remove tank_old and the z2 vdev, and re-purpose the physical disks. I would like the put the 2x 4TB's into a mirror and have that as a separate pool for Photo's/Doc's etc and setup a nightly backup to an external hdd.
With the remaining 2TB's, would there be any harm in setting them up as another z2 and adding that vdev to tank_new?
