I'm considering setting up a FreeNAS system (or actually two; one will act as a backup) with 5 SATA HDs (3 TB each, RAIDZ1). This does not need to be a very high performance system. There are only a few PCs connected (through Gigabit ethernet), and its for data storage/archival only - no programs are running from the NAS and there is no database activity etc. I'd like to be able to expand the system in the future. Given that adding disks to an existing vdev isn't possible, that means that I'd like to have some way of adding an additional 5-disk RAIDZ1. Ideally in the same enclosure, but I'd accept a solution that has the first 5 disks internally, and needs add-on hardware/enclosure for the future expansion.
While I'd like to setup a full custom system, I simply do not have the time to do so. Instead, I'm looking for an off-the-shelf solution where I just add some disks, and install FreeNAS. However, it seems hard to find something in between the Intel Atom things and expensive Xeon-systems that supports at least 5 3.5" HDs (see my comment about extending the number of HDs above). I guess a workstation is powerful enough, but they often take just 4 disks.
What do people generally use in such a case? Any recommendation?
