Hi, had to reboot and used the opportunity for an quick update from Truenas Scale 'RC2' to 'release'.
I use NFS for proxmox, and after the reboot I cannot see any vmdisks (.qcow2). However, the backups are visible in the GUI. The qcow2 files are there, but permissions. From proxmox:
I can get into 'images' but not further. Also, on truenas
I don't know if this is even close to the correct way of solving this is what I did:
and I think everything is working again... Was this the correct way of fixing the problem?
cd /mnt/pve/nfsTN10G/images/ ls 100 101 cd /mnt/pve/nfsTN10G/images/100: Permission denied
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# cd 100 root@truenas[/mnt/wdmirror/proxmoxNFS/images/100]# ls vm-100-disk-0.qcow2
root@truenas[/mnt/wdmirror/proxmoxNFS/dump]# cd /mnt/wdmirror/proxmoxNFS/images
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# ls -l
total 1
drwxr----- 2 root root 3 Jan 8 11:11 100
drwxr----- 2 root root 3 Jan 5 21:10 101
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 100
total 1
drwxrwx--- 2 root root 3 Jan 8 11:11 100
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 101
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 100/*
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 101/*
total 1
drwxrwx--- 2 root root 3 Jan 5 21:10 101
