RC2 to 20.02.0 NFS inconsistent permissions - did I solve my problem?
otpi
Hi, had to reboot and used the opportunity for an quick update from Truenas Scale 'RC2' to 'release'.
I use NFS for proxmox, and after the reboot I cannot see any vmdisks (.qcow2). However, the backups are visible in the GUI. The qcow2 files are there, but permissions. From proxmox:
cd /mnt/pve/nfsTN10G/images/
ls
100 101
cd /mnt/pve/nfsTN10G/images/100: Permission denied
I can get into 'images' but not further. Also, on truenas
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# cd 100
root@truenas[/mnt/wdmirror/proxmoxNFS/images/100]# ls
vm-100-disk-0.qcow2
I don't know if this is even close to the correct way of solving this is what I did:
root@truenas[/mnt/wdmirror/proxmoxNFS/dump]# cd /mnt/wdmirror/proxmoxNFS/images
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# ls -l
total 1
drwxr----- 2 root root 3 Jan  8 11:11 100
drwxr----- 2 root root 3 Jan  5 21:10 101
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 100
total 1
drwxrwx--- 2 root root 3 Jan  8 11:11 100
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 101
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 100/*
root@truenas[/mnt/wdmirror/proxmoxNFS/images]# chmod 770 101/*
total 1
drwxrwx--- 2 root root 3 Jan  5 21:10 101
and I think everything is working again... Was this the correct way of fixing the problem?
otpi
Not at my lab, so cannot check versions. Should be whichever is the default? I installed Scale RC2, created a dataset proxmoxNFS and share, then mounted that share in proxmox (v7). ids? Guessing root/root?
anodos
Sambassador
Okay. We switched to knfsd for release, and exports defaults to "root_squash", which means that you may have been ending up with anonuid / anongid (defaults to nobody:nobody). If you want to use root:root for some reason, then set maproot_user and maproot_group to root / root.
