Recently I try to create a FreeNAS server with 3 disks of 1TB (ST1000DM010-2EP102) but I get random restarts of the disks as some dissapear and reappear without touch anything
on the UI/storage/disk sometimes the disk isn't on it, other appear but take some time
trying to format it (wipe with zeros) and I reach any % and the wipeing Disk process stop as it will be finnish
when I try to add it (replace) a disk from other pool with one of this one and I can do it, when I try to add another one the % on the resilvering process come back and start it again from 0% allmost forever
My 2 systems
core2quad with 8 GB of RAM https://www.msi.com/Motherboard/support/P965_Platinum (FreeNAS-11.3-U3.2 on 1 USB of 16GB)
Ryzen 3600G with 16GB of RAM https://www.gigabyte.com/Motherboard/B450M-S2H-rev-10 (FreeNAS-11.3-U3.2 on 2 USB of 32GB)
Xeon x5680 with 24GB or RAM https://www.asus.com/Motherboards/P6T_WS_Professional/ (Windows server 2008 R2 Datacenter)
Ryzen 3 3900X with 32GB of RAM https://www.asus.com/Motherboards/PRIME-X570-PRO/ (Linux Debian 10 & Linux Mint 20)
Happen the same on both systems with FreeNAS, is allmost impossible to use it
on both Windows and Linux machine the disk work perfect
NOTE: the "Hardware ECC recovered" value didn't appear to be right and sometimes that value reset itself and look more like the number of sector read/writes on the disk, I get 62.100 M of errors and today have a raw value of 0x06B9
Someone ask me to test it with a diferent power Supply but that isn't the problem as I test it with 3 diferent powerSupply (of more enought power) and 2 USB HDD case and fail on all
NOTE: The problem appear on the Screen attack to the sever but not on every case
My 2 systems
