Hello everyone,
I have a supermicro X10SL7-F motherboard which has 4 ram slots.
I was running 2x8GB ram (CT102472BD160B) on DIMMA1 and DIMMA2. The ram had been tested and working for 6-7 years.
In order to complete the ram on my system, I purchased two additional ram CT102472BD160B to have the maximum 32GB of ram.
When I inserted the new ram into the remaining slots (DIMMB1 and DIMMB2) to test the whole thing with memtest86, the system seemed to boot "correctly". Then at the next reboot I had 4 short beeps at the time of the system initialization. Series of beeps that are not the usual ones of the card and the system crashed without going further.
I went on a big investigation and I'll pass on some of the details.
I made a first series of tests :
_ Each ram bar was tested alone on DIMMA1 (4 pass with memtest86 version 9.4 free) => no error detected
When I put two ram bars (whatever the bar) on DIMMA1 and DIMMA2, I have no problem (no beeps) and the system boots normally.
I did a second series of tests : each ram bar was tested alone on each of the 4 slots (DIMMA1, DIMMA2, DIMMB1 and DIMMB2)
Test protocol:
1] launch a linux mint liveUSB with short navigation (open software, browse folders, no more than 1 minute)
2] shutdown
3] launch memtest86 (1 pass / 13 tests)
4] Ctrl+Alt+Del to reboot the system
5] on reboot, launch LiveUSB linux mint with short navigation (open softwares, navigate in folders, not more than one minute)
Several remarks on the results:
_ no matter what bar and location (16 tests), no error was detected by memtest86.
_ at no time did I get the 4 error beeps at startup. I only got the normal beeps when everything is fine.
_ the two memory sticks I just bought work on all 4 slots without any problem.
_ I have had problems with both of my existing memory sticks.
_ the problems occurred only on channel B => DIMMB1 and DIMMB2
_ for the pairs of strip/slot where there were problems => I never had latency or other problems at the first boot. It's during the second boot that it's not so good and where it happens (very, very) big latencies.
Third series of tests:
I have tried several pairs of barrette/slot with two, three or four barrettes
I have problems of big latency if I put the two strips that worked alone on DIMMB1 & B2 together.
I have the impression that as soon as I put the B channel in, there are problems.
I have noticed that if I make a change (remove a ram, put one back,...), the system starts up for the first time without any problem.
On the other hand, as soon as the second boot, either the system beeps (4 short beeps) and doesn't go any further, or the system does a looped reboot, or I get to the OS (windows or linux) but it's very very very slow (even freezes).
I would also like to point out that :
I disassembled the motherboard to see if there were bad soldering, if there were pins that could not make contact, inflated capacitor, .... => nothing visible
I dismantled the processor and cleaned the contacts => no effect
Do you have any idea of the problem?
Test protocol:
2] shutdown
