jovialwoodchuck
- Mar 11, 2013
Hi all, I've been using FreeNas for almost a year now, and it's been great. I started out with 4 2TB drives in RaidZ, then awhile later added a 3TB drive and used the GUI expand method. This worked perfectly, and raised me from 5.3TB available storage to around 8TB. That was a few months ago, and everything has been working great.
It's currently running in an old desktop I had, hooked directly to the SATA ports on the motherboard. Yeah, not the fastest thing in the world, but it works. I recently decided to upgrade to some better hardware, so I transferred it to a new case setup. During that process, through general stupidity on my part, the newest drive (3TB) was dropped, and is no longer usable. No problem right? This is RaidZ, so a single drive failure won't be an issue? Wrong. I got everything set back up, and it would not import. I've tried everything I can think of, but no go.
I've since hooked everything back up in the original case/hardware setup, in case the new hardware was the issue, but I'm still having the same issue. The only thing I'm not positive on is which drive was hooked to which SATA port, but that shouldn't matter right?
My critical data is backed up elsewhere, but there's still a great deal on here I'd prefer to not lose if possible. Any input would be greatly appreciated. I've included a screenshot of what zpool import does.
