Raidz volume Problem on 8.0.3 64 bit
r.schweiger
Hi @ll,
My FreeNAS is showing me the following error on my raidz volume:
Error getting available space Error getting total space
Can anybody pls. tell me, what that msg means or what I have to do
to get the volume mounted for recovery?
The Screenshot will show you the Problem.
Many THX in advance!
Kind Regards
RS
  • ScreenShot FreeNAS.pdf
William Grzybowski
How did you create that volume? Was it imported from older version?
Post the output of "zpool status" and "zpool import"
r.schweiger
It is an imported volume after an upgrade from 8.0.1.
Here is the ouput of zpool import:
[root@freenas] ~# zpool import
pool: Multimedia
state: UNAVAIL
status: One or more devices contains corrupted data.
action: The pool cannot be imported due to damaged devices or data.
see: http://www.sun.com/msg/ZFS-8000-5E
Multimedia UNAVAIL insufficient replicas
gptid/ac657c02-d08a-11e0-8256-001e0b2e3e91 ONLINE
gptid/aeeb9911-d08a-11e0-8256-001e0b2e3e91 ONLINE
zpool status:
[root@freenas] ~# zpool status
pool: Backup
state: ONLINE
scrub: none requested
NAME STATE READ WRITE CKSUM
Backup ONLINE 0 0 0
gptid/45dcd7b4-ccdb-11e0-a38c-001e0b2e3e91 ONLINE 0 0 0
errors: No known data errors
Thank you 4 your help!
KR
RS
William Grzybowski
Well, looks like your Multimedia corrupted due to bad sectors/media or something...
To be honest I'm not sure if there is anything you can do to recover this, maybe try booting a FreeBSD 9.0 with zfs v28 but that will require a bit of knowledge...
r.schweiger
Many thx for your help!
I am hoping to find a solution to get the data recoverd...
Kind Regards
RS
