RandomPedestrian
- Dec 27, 2023
I want to build a dedicated NAS around tax time. I've been having issues with my Unraid server and would like to make the TrueNAS build focused on just being a reliable NAS, moving all my dockers and VMs to other dedicated machines (barring maybe something like Syncthing or backup-related services).
Goals:
My first question is: What does an ideal pool look like if I want to go with 8, 20(ish) TB drives? I'm fine losing two drives worth of storage to RaidZ2, but is there a more optimal configuration?
The second question is on the motherboard/CPU/RAM choices. Is it unwise to go with desktop-grade hardware? My first thought was an AM5 board with a Ryzen 5 since, as far as I'm aware, I don't need anything higher-spec for a NAS that won't be running VMs and dockers.
My only reservation is that I'm unsure how ECC compatibility is with AM5 boards. I've heard of some success stories with particular boards, but this will be my first time ever using ECC.
For example, one of the part lists I had put together looked something like:
Goals:
- TrueNAS build will be single-function as only a NAS (all dockers/VMs in the homelab will be run on other computers)
- Initial pool of 8 spinning drives, with the possibility of adding more later
- Primary purpose of the storage is as a media/backup server, rarely if ever will it ever see any use cases where I'd need an SSD pool
- Desktop form factor (Fractal Define 7, for example) for low noise as it'll be in a high-traffic room
- 10Gbe would be preferred, but currently on a 2.5Gbe network
- 8, 20TB Seagate Ironwolf Pro (Exos is fine too depending on the price)
- Ryzen 5 7600
- ASUS X670E ProArt (this seems completely overkill and I'm welcome to better alternatives, but it does have a 10Gb NIC standard)
- 4x32GB DDR5 ECC UDIMM
- Fractal Define 7
- Any 80Plus Gold/Platinum Power Supply
