shadowkillerdragon
- Apr 29, 2013
Hi all,
I was setting up my FreeNAS build and trying to get the controller to be flashed into IT mode, but for some reason it doesn't seem to be found by the sas2flash.efi command. I get the simple no lsi controller found and when trying the equivalent command in freedos i get Causeway error 07: unable to control A20 whenever i try to run sas2flsh.exe
I believe I should be seeing a LSI bios prompt during the boot up process as well with ctrl+c to be able to access it, but nothing of the sort appears. So I decided to just install FreeNAS to a flash drive and boot it up. It should see drives even without flashing the controller to IT mode, or at least give me a Firmware version doesn't match.
I'm using a HPE ML10 gen 9 with 20gb of ram and a Seasonic M12 620W. Plugging into the internal sata connectors boots and see drives fine.
Is the card doa?
Is the card doa?
