Doug Hall
- Jun 10, 2013
Hardware:
Motherboard: SuperMicro MBD-X9SCM-F-O LGA 1155
CPU: Intel Xeon Quad-Core Processor E3-1230 v2 3.3GHz
Memory: 16GB Kingston Technology ValueRAM (2 x 8GB 1600MHz DDR3 PC3-12800 ECC)
HDD: Seagate 4TB NAS HDD SATA (6 x 4TB)
FreeNAS: 9.1.1
I made this for a friend in September, 2013. She called, saying it wouldn't boot after an extended power outage. (Yes, I had it protected by a CyberPower SineWave UPS, and it should have quit normally, after ten minutes of no power.) After connecting through IPMI interface, I saw that it was having a "Media test failure, check cable" (PXE-E61) error. After that, it exits the Intel Boot Agent. Sounds like the USB stick went bad, to me. Has anyone else seen this?
I have a backup of the configuration settings and encryption key, but I need some advice on what to do next. Do I just do a fresh install of the latest version, to another USB drive, and restore her settings, or should I use the FreeNAS version that was installed (9.1.1)?
FreeNAS: 9.1.1
