John C. Reid
 - Jan 29, 2016
I have been searching for hours and I can not seem to figure this out. I know it must be simple, but I cannot find a workable instruction to follow.
I am running FreeNAS-9.3-STABLE-201511280648 on a Dell PowerEdge 2950. I have OwnCloud 8.2.1 installed via the plugin (the installed plugins page states PBI owncloud-8.2.1-amd64)
Currently it is working and exposed to the Internet via a domain name. It is using SSL and only allow connection via https. It is currently working with a self-signed cert that was taken care of by the plugin install. Now I need to replace the self signed cert with a purchased one. I already generated the CSR and purchased the cert from GoDaddy. I have received the zip file with the two crt files, one of them is a bundle.
The issue is that I can't figure out at this point what to do with those files to install them on the server, and have it use the cert from the trusted authority rather than the self signed one. I am feeling a bit like an idiot at the moment. Any help would be greatly appreciated.
Thank you.
Thank you.
