PSU EVGa vs Seasonic
jgreco
Resident Grinch
Well, just from wattage, the Seasonic is better. They're also generally well-respected for build quality, but EVGA isn't crappy either.
You might want to review the following:
to make sure you're picking a sufficiently large PSU.
firesyde424
These days, it's less an issue of "better" than it is an issue of "enough." Assuming you stick to the larger, recognizable brands, most power supplies are going to be just fine for most use cases. The important part is to not only make sure that your power supply has sufficient capacity for your system, but that it will continue to be able to provide power as it ages and becomes less efficient.
