Propose High-End (ish) Specification: Xeon E5, 8* WD Reds, SuperMicro case+PSU, UPS
Hazimil
Hi All, after an earlier post for advice and further reading research, I have come up with the following spec, your feedback would be appreciated.
Usage: The NAS is to replace my old ReadyNAS 314, and is to be used as a home-network storage for the family, storing media files (photos, videos, and .MKV Rips), as well as to operate as a Plex server. More options/uses may come online as I get used to the box and my confidence increases :). I'm looking for a box which can sit in the corner, be future-proofed (well as future-proofed as you can be), and run happily for a few years!
Proposed Specification:
CASE: SuperMicro 745TQ [ATX, 8* hot-swap bays, various PSU options, 2* FAN-0082L4, 3* FAN-0074L4]
PSU: Included with above case, can choose from 800W, 920W, 1200W, 1280W [all redundant]
MOBO: ASRock X99 Taichi [LGA 2011-v3, Intel X99, 10* SATA 6Gb/s, USB 3.1, USB 3.0, Dual Intel Gigabit LAN, ATX]
CPU: Intel Xeon E5-1650 [v4 Broadwell, 3.6 GHz, LGA 2011-3, 140W, BX80660E51650V4]
CPU FAN: Cooler Master Hyper 103 Air CPU Cooler
RAM: Crucial 64GB [4 x 16GB 288-Pin DDR4 SDRAM ECC DDR4 2133 (PC4 17000) (CT4K16G4RFD4213)]
BOOT DRIVE: SanDisk Ultra II [2.5" 240GB SATA III Internal Solid State Drive (SSD) SDSSDHII-240G-G25]
DATA DRIVE: WD Red 8TB [*8, RaidZ2 or RaidZ3 configuration]
To determine the PSU size I've calculated the wattage as follows, using the manufacturers guidance (if found) otherwise the guidance written by @jgreco :
MOBO: Nothing on ASRock website, but looking at online reviews it ranges from 110W to 278W (say 300W)
CPU: Intel specification states a Thermal Design Power of 140W
CPU FAN
: Cooler Master specification states 1.8W (say 2W)
RAM: Using @jgreco guidance, 4 * 6W = 24W
BOOT
: The drive specifications state 85mW active power with 4.5W max write use (say 5W)
DATA: The WD Reds 8TB specification states 1.79 12VDC Amps which equals 21.48W with a 6.4W operational usage = 27.88W (say 28W * 8 = 224W)
CASE FANS: The case fans specification states 0.58 12VDC Amps which equals 6.96W (say 7W * 5 = 35W)
This equates to a total wattage of 730W (*1.25 = 912.5W), however if I add another 64GB of RAM this would increase to 754W (*1.25 = 942.5W), so I think 1200W PSU would be best. I also need a UPS to support this, and am thinking of:
UPS: APC Smart-UPS (2200VA, 1980W, LCD, 230V)
Feedback on the proposed specification as well as my Wattage use calculation would be welcomed.
Thanks.
Yours
Jonathan
Dice
Looks like solid homework to me.
Nope. Get a proper server board, either from Supermicro or ASRock Rack. Definitely not a an X99 board.
Stux
Stux
https://www.amazon.co.uk/Super-Micr...ie=UTF8&qid=1494483052&sr=8-2&keywords=x10sri
This one has 10 SATA ports and 2 Intel LAN chips and can actually use ECC and a Xeon CPU.
Which is a great board if you need a PCIe3 x16 slot. Otherwise its worth considering the X10SRL-F, which has *five* PCIe3 x8 slots for the ultimate in extensibility, but is lacking a x16 slot. The only downside then is its ethernet ports are not as efficient for VMs as the X10SRi-F.
Or 4 PCIe3 x8 and 2 PCIe3 x4, enough for a couple of PCIe NVMe SSDs, a couple of HBAs and a couple of 10 or 40 gbit NICs. Dang.
Hazimil
Thanks for the feedback, back to the drawing board to look for a different Motherboard (and no doubt RAM and Wattage usage!) :)
Working this out sure has been educational!
Jonathan
religiouslyconfused
On Amazon UK, X10SRi-F is actually cheaper than the X10SRL-F.
