Progs installieren auf Freenas 8.02 fehler
Coolzero
Hallo, ich wollte verschiedene Programme, unrar, java, amule auf meinem Freenas 8.02 installieren, die installationen brechen immer ab, mit fehlermeldungen wie dieser:
 pkg_add -rv unrar
scheme:   [ftp]
user:     []
password: []
host:     [ftp.freebsd.org]
port:     [0]
document: [/pub/FreeBSD/ports/amd64/packages-8.2-release/Latest/unrar.tbz]
---> ftp.freebsd.org:21
looking up ftp.freebsd.org
connecting to ftp.freebsd.org:21
<<< 220 Welcome to freebsd.isc.org.
>>> USER anonymous
<<< 331 Please specify the password.
>>> PASS root@freenas.local
<<< 230 Login successful.
>>> PWD
<<< 257 "/"
>>> CWD pub/FreeBSD/ports/amd64/packages-8.2-release/Latest
<<< 250 Directory successfully changed.
>>> MODE S
<<< 200 Mode set to S.
>>> TYPE I
<<< 200 Switching to Binary mode.
setting passive mode
>>> PASV
<<< 227 Entering Passive Mode (204,152,184,73,198,151).
opening data connection
initiating transfer
>>> RETR unrar.tbz
<<< 150 Opening BINARY mode data connection for unrar.tbz (97005 bytes).
Fetching ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.2-release/Latest/unrar.tbz...Waiting for final status
x +CONTENTS
x +COMMENT
x +DESC
x +MTREE_DIRS
x bin/unrar<<< 226 Transfer complete.
x share/doc/unrar/license.txt
x share/doc/unrar/readme.txt
tar command returns 0 status
 Done.
extract: Package name is unrar-4.00.b4,5
extract: CWD to /usr/local
extract: /usr/local/bin/unrar
extract: /usr/local/share/doc/unrar/license.txt
extract: /usr/local/share/doc/unrar/readme.txt
bin/unrar: Could not unlink
share/doc/unrar/license.txt: Failed to create dir 'share/doc'Can't create 'share/doc/unrar/license.txt'
share/doc/unrar/readme.txt: Failed to create dir 'share/doc'Can't create 'share/doc/unrar/readme.txt'
tar: Error exit delayed from previous errors.
pkg_add: leave_playpen: can't chdir back to ''
Hab dann mal google bemüht und bin hierrüber gestostolpert:
 Tthe problem is you need to enable the partition writable. This is a BAD idea because the size of the partitions is very limited and you could end up needing to reflash you USB stick. It is possible with maybe a couple 'small' packages, but not recommended if you are not sure what you're doing. Also pkg_add doesn't update the package database like FreeBSD, so if you mess up you can't just do a pkg_del.
Mein Englisch ist nicht das beste, aber ich würde sagen mein freenas partition ist nicht writable!?
Also ich hab freenas auf einem 8GB USB Stick installiert, kann ich den dann writable machen?
Wie?
Danke
ProtoSD
Die Größe der Festplatte macht es keinen Unterschied, ist die Größe der Partition konstant. Sie können die Partition beschreibbar mit "mount-uw /"
Mein Deutche ist nicht das beste entweder ;-)
Coolzero
Super, danke für die schnelle Antwort.
Kann mir jetzt noch einer sagen wie ich amule auf dem freenas installiert bekomme?
Bekomme immer diese Fehlermeldung bei einem
code]pkg_add -rv amule[/code]
folgende Fehler bringt:
Seek failed
x lib/perl5/5.10.1/shellwords.pl: Seek failed
x lib/perl5/5.10.1/sigtrap.pm: Seek failed
x lib/perl5/5.10.1/sort.pm: Seek failed
x lib/perl5/5.10.1/stat.pl: Seek failed
x lib/perl5/5.10.1/strict.pm: Seek failed
x lib/perl5/5.10.1/subs.pm: Seek failed
x lib/perl5/5.10.1/syslog.pl: Seek failed
x lib/perl5/5.10.1/tainted.pl: Seek failed
x lib/perl5/5.10.1/termcap.pl: Seek failed
x lib/perl5/5.10.1/timelocal.pl: Seek failed
x lib/perl5/5.10.1/unicore/ArabicShaping.txt: Seek failed
x lib/perl5/5.10.1/unicore/BidiMirroring.txt: Seek failed
x lib/perl5/5.10.1/unicore/Blocks.txt: Seek failed
x lib/perl5/5.10.1/unicore/Canonical.pl: Seek failed
x lib/perl5/5.10.1/unicore/CaseFolding.txt: Seek failed
x lib/perl5/5.10.1/unicore/CombiningClass.pl: Seek failed
x lib/perl5/5.10.1/unicore/CompositionExclusions.txt: Seek failed
x lib/perl5/5.10.1/unicore/Decomposition.pl: Seek failed
x lib/perl5/5.10.1/unicore/EastAsianWidth.txt: Seek failed
x lib/perl5/5.10.1/unicore/Exact.pl: Seek failed
x lib/perl5/5.10.1/unicore/HangulSyllableType.txt: Seek failed
x lib/perl5/5.10.1/unicore/Index.txt: Seek failed
x lib/perl5/5.10.1/unicore/Jamo.txt: Seek failed
x lib/perl5/5.10.1/unicore/LineBreak.txt: Seek failed
x lib/perl5/5.10.1/unicore/Name.pl
/var: write failed, filesystem is full
: Seek failed
x lib/perl5/5.10.1/unicore/NameAliases.txt: Seek failed
x lib/perl5/5.10.1/unicore/NamedSequences.txt: Seek failed
x lib/perl5/5.10.1/unicore/NamedSqProv.txt: Seek failed
x lib/perl5/5.10.1/unicore/NamesList.txt: Seek failed
^CSignal 2 received, cleaning up..
bubulein
Moin,
ohne ein Basiswissen zu FreeBSD und der Shell würde ich die Finger davon lassen.
Um auf dein Problem zukommen sagen deine Logs doch alles:
Dateisystem voll!!! /var: write failed, filesystem is full
Sprich, die /var Partition ( im RAM) ist zu klein.
Unionfs würde da weiter helfen.
-Christian
Coolzero
Ok Datensystem voll hatte ich auch verstanden, obwohl ich mir das bei dem 8Gb Stick eigentlich nicht vorstellen kann!?
Ich hab mal en bisschen bash erfahrungen mit opensuse gemacht, wovon würdest du die finger lassen?
Was ist unionfs?
fyysh
Bubulein hat Recht. Du scheinst, deinen bisherigen Posts zur Folge, nicht über genug Wissen über FreeBSD bzw. Unixe allg. zu verfügen, um solche Sachen in FreeNAS zu installieren.
Ich würde an deiner Stelle aber auch nicht mit Unionfs hantieren. Besser du machst dir ne Jail und lässt die Finger (weitestgehend) vom (Basis)System. Anleitungen findest du hier im Forum genug (allerdings auf Englisch). In der Jail kannst du dann rumsauen/lernen, ohne dass deine FN betroffen ist. Wenn du dann noch mit ZFS Snapshots hantieren kannst, kann dir überhaupt nichts passieren. Du machst einfach deine Jail beim Rumsauen platt, stellst den Snapshot wieder her und kannst es das nächste Mal richtig machen... ;)
Ein weiterer Vorteil ist es, dass es ein Klacks ist, deine FN-Anpassungen nach einem Firmware-Upgrade wieder ans laufen zu bekommen (wobei das auch auf unionfs zutrifft - aber da besteht einfach die Gefahr, dass du FN platt machst).
Coolzero
Hallo,
das ich mich mit BSD nicht wirklich auskenne muss ich wohl leider zugeben, allerdings sind in Freenas 8.03(hab ich nun aktuell drauf) auch eine Menge Bugs vorhanden, die das leben damit schwer machen.
Bin daher erstmal davon abgerückt was auf Freenas zu installieren.
fyysh
Was hast du denn benutzt, dass du über eine "Menge Bugs" gestolpert bist?
Coolzero
Re
Hallo,
Zum einen hatte ich einen Benutzer "Thomas" angelegt und dann eine Cifs Freigabe eingerichtet, als ich dann versuchte über win7 auf meine shares zuzugreifen, wurde keine Anmeldung zugelassen!
Nach viel hin und her hab ich dann den Benutzer einfach "thomas" ( mit kleinem t diesmal" )genannt, und siehe da ich konnte direkt drauf zugreifen! Also stimmt irgendwas mit der groß und Kleinschreibung nicht! Das linux/Unix zwischen groß und klein unterscheidet ist mir schon klar, aber das war hier nicht das Problem!
Ein weiterer Fehler ist das ich eine Gruppe "Eigentümer" angelegt hatte, als ich dann versuchte für die zfs datasets die Berechtigungen zu pflegen, kam immer ein traceback(da ich im mom nicht am pc bin kann ich den nicht Posten, kann ich aber morgen nachholen!)
Nachdem ich die Gruppe in "eigentuemer" geändert hab ging es direkt wieder! Entweder liegts wieder an der groß Kleinschreibung oder am ü
