hungarianhc
- Mar 11, 2014
Hey There,
I know this question might sound stupid. I understand that having a single hard drive means if the drive fails, you lose all the data. However, I'm going to be retooling my system, and I'm going to move to a RAIDZ1 SSD array, and I'd like to have a single 3.5" drive that I use for two purposes: Apple Time Machine and doing ZFS replication from one of my pools on the SSD array to the HDD.
I'm totally okay with the HDD not being redundant, but how does replacing it work, logistically, and where is the metadata stored? Meaning... Let's say I have two datasets on the drive. One is for Apple Time Machine backups, and the other is for backups of my media library. Disk dies. Bummer. I get a new disk... I offline the bad disk, and I pop the new one in. Will it still have the ZFS dataset on it (i.e. will TrueNAS create it), and will there still be an SMB share on the dataset, and will the ZFS replication for the media backup continue to work?
This is literally going to be a 4th copy of my data (i have two offsite backups), so I'm okay with the downtime / risk of data loss, but there's an operational recovery aspect I want to make sure I understand. If I have to recreate datasets, re-point the SMB share to the new dataset, update the ZFS replication task, etc, that'll be a pain tin the butt. Thanks!
