Problems with write operations from macOS to SMB share after upgrade to 11.3
tmueko
Member
Problem: I can mount am smb-share and change a file with vi or BBedit. I cant change the file using textedit. I can copy the file to mac, edit and copy back.
Server is on AD-Directory.
ACL are OK, I thinK:
root@claus[~]# getfacl /mnt/pool01/hannover/_ACL_TEST
# file: /mnt/pool01/hannover/_ACL_TEST
# owner: CC\administrator
# group: CC\domänen-benutzer
            owner@:rwxpDdaARWcCos:fd-----:allow
            group@:rwxpDdaARWcCos:fd-----:allow
         everyone@:--------------:fd-----:allow
this is smb-share (there is also an deaktivated afp-share.
[_ACL_TEST]
    aio write size = 0
    ea support = No
    mangled names = illegal
    path = /mnt/pool01/hannover/_ACL_TEST
    read only = No
    vfs objects = fruit streams_xattr shadow_copy_zfs ixnas
    nfs4:acedup = merge
    nfs4:chown = true
    fruit:resource = stream
    fruit:metadata = stream
This is log.smb from an open, change, try to write. I far as I can see he creates a folder "filename.suffix-sb-<random>".
There is a "failing" chmod but I don't know why this fruit-module tries to chmod on an ACL enabled share!?
can someone point me to the right direction?
[2021/02/16 08:27:12.420037,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt read=Yes write=Yes (numopen=3)
[2021/02/16 08:27:12.420885,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt read=No write=No (numopen=4)
[2021/02/16 08:27:12.420973,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt (numopen=3) NT_STATUS_OK
[2021/02/16 08:27:12.421787,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.421882,  1] ../../source3/modules/vfs_fruit.c:6356(fruit_fset_nt_acl)
  chmod: test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt, result: -1, 0644 error Operation not permitted
[2021/02/16 08:27:12.421913,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.423647,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.423716,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.427037,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt (numopen=2) NT_STATUS_OK
[2021/02/16 08:27:12.428732,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt read=No write=No (numopen=3)
[2021/02/16 08:27:12.428845,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.429580,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.429679,  1] ../../source3/modules/vfs_fruit.c:6356(fruit_fset_nt_acl)
[2021/02/16 08:27:12.429707,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.432523,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt read=Yes write=No (numopen=3)
[2021/02/16 08:27:12.433214,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt read=Yes write=No (numopen=4)
[2021/02/16 08:27:12.433911,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt read=No write=No (numopen=5)
[2021/02/16 08:27:12.434060,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt (numopen=4) NT_STATUS_OK
[2021/02/16 08:27:12.434720,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.434857,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.435457,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt (numopen=3) NT_STATUS_OK
[2021/02/16 08:27:12.435960,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.436590,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt read=No write=No (numopen=3)
[2021/02/16 08:27:12.436718,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt (numopen=2) NT_STATUS_OK
[2021/02/16 08:27:12.437417,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.437512,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.438281,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.438421,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt:com.apple.lastuseddate#PS read=Yes write=No (numopen=4)
[2021/02/16 08:27:12.439039,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt:com.apple.lastuseddate#PS (numopen=3) NT_STATUS_OK
[2021/02/16 08:27:12.439067,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.439703,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.439897,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt:com.apple.lastuseddate#PS read=No write=Yes (numopen=4)
[2021/02/16 08:27:12.441879,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt:com.apple.lastuseddate#PS (numopen=3) NT_STATUS_OK
[2021/02/16 08:27:12.441931,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.442643,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.442702,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.443556,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.443611,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.444588,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.444646,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.445477,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.445558,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.446298,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.446407,  1] ../../source3/modules/vfs_fruit.c:6356(fruit_fset_nt_acl)
  chmod: test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt, result: -1, 0770 error Operation not permitted
[2021/02/16 08:27:12.446434,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.448218,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt:com.apple.lastuseddate#PS:$DATA read=No write=No (numopen=3)
[2021/02/16 08:27:12.448260,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-Ja2ekC/test2.txt:com.apple.lastuseddate#PS:$DATA (numopen=2) NT_STATUS_OK
[2021/02/16 08:27:12.448305,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.448558,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.627603,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file .DS_Store read=No write=No (numopen=4)
[2021/02/16 08:27:12.627754,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file .DS_Store:AFP_AfpInfo read=Yes write=No (numopen=5)
[2021/02/16 08:27:12.627829,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file .DS_Store:AFP_AfpInfo (numopen=4) NT_STATUS_OK
[2021/02/16 08:27:12.627851,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file .DS_Store (numopen=3) NT_STATUS_OK
[2021/02/16 08:27:12.631160,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file untitled text 504.txt read=No write=No (numopen=3)
[2021/02/16 08:27:12.631351,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file untitled text 504.txt (numopen=2) NT_STATUS_OK
[2021/02/16 08:27:12.632536,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.632685,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.634347,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.634538,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:12.635481,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:12.635627,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:13.128859,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:13.129094,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:13.130051,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:13.130193,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:13.131639,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:13.131787,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:13.132735,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:13.132871,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.726541,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt read=Yes write=Yes (numopen=3)
[2021/02/16 08:27:14.729493,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt read=No write=No (numopen=4)
[2021/02/16 08:27:14.729596,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt (numopen=3) NT_STATUS_OK
[2021/02/16 08:27:14.730469,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.730597,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.732297,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.732366,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.736272,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt (numopen=2) NT_STATUS_OK
[2021/02/16 08:27:14.738017,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt read=No write=No (numopen=3)
[2021/02/16 08:27:14.738104,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.738545,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.738684,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.738757,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.738779,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.739058,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.739187,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.743479,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.744316,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt read=Yes write=No (numopen=4)
[2021/02/16 08:27:14.745119,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.745271,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.745982,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.746117,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.746737,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.747287,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.748005,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.748135,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.751881,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.752002,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.752953,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.753088,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.753733,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.753761,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.754505,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.754703,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt:com.apple.lastuseddate#PS read=No write=Yes (numopen=4)
[2021/02/16 08:27:14.756624,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt:com.apple.lastuseddate#PS (numopen=3) NT_STATUS_OK
[2021/02/16 08:27:14.756673,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.757479,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.757536,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.758524,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.758576,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.759545,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.759595,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.760440,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.760517,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.761330,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.761450,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.764465,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt:com.apple.lastuseddate#PS:$DATA read=No write=No (numopen=3)
[2021/02/16 08:27:14.764517,  2] ../../source3/smbd/close.c:807(close_normal_file)
  CC\tmueko closed file test2.txt.sb-9a0f00ab-F7G1AP/test2.txt:com.apple.lastuseddate#PS:$DATA (numopen=2) NT_STATUS_OK
[2021/02/16 08:27:14.764566,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.764793,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.818540,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.818708,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.819482,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.819621,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.820786,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.820920,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.821650,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt read=Yes write=Yes (numopen=3)
[2021/02/16 08:27:14.822434,  2] ../../source3/smbd/open.c:1447(open_file)
  CC\tmueko opened file test2.txt read=No write=No (numopen=4)
[2021/02/16 08:27:14.822494,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.860532,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.860754,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.861680,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.861826,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:14.913164,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:14.913355,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:15.013222,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:15.991666,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:15.991826,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:15.991907,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:15.991930,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:15.996077,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:15.996248,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:15.997100,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:15.997238,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:15.998395,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:15.998542,  2] ../../source3/smbd/close.c:807(close_normal_file)
[2021/02/16 08:27:15.999433,  2] ../../source3/smbd/open.c:1447(open_file)
[2021/02/16 08:27:15.999565,  2] ../../source3/smbd/close.c:807(close_normal_file)
tmueko
Member
OK, carrying everything together helped a bit:
when I disable "fruit" (add an aux paramter to disable vfs_fruit): everything is fine with that share:
vfs objects = streams_xattr shadow_copy_zfs ixnas
Now when I only connect to my _ACL_TEST everything is fine.
note: when I first connect to a share with fruit enabled an then connect to my "_ACL_TEST" I am doomed again (which is documented not to mix fruit enabled with not enabled).
tmueko
Member
after additional hours of debugging I found the problem:
Some of the dataset has been created "aclmode = restricted" (maybe share Type = SMB).
with aclmode = passthrough (zfs inherit aclmode ...) everything is working fine even with vfs_fruit enabled.
thanks for reading. please close.
