Problems with Plex plugin in TrueNAS 12
Garyw
Hi all,
I'm trying to deploy Plex to my TrueNAS box but the deployment gets this error:
Error: plex had a failure Exception: RuntimeError Message: pkg error: - pkg-static: http://pkg.FreeBSD.org/FreeBSD:12:amd64/latest/All/pkg-1.16.2.txz: Not Found Please check your network Partial plugin destroyed
There are no DNS or networking issues as I can resolve other domains and connect to the TrueNAS box.
Any suggestions?
thanks!
You might not have internet in that jail. Verify?
G8One2
Use DCHP instead of NAT, it will install. Probably a NAT issue, but idk.
pschatz100
That link doesn't resolve. I just clicked on it and no go...
You didn't say how you are installing Plex, but I would check your procedure.
